my truck is a no start after changing heads
Old Nov 4, 2009 | 07:45 PM
ss64impala's Avatar
Default my truck is a no start after changing heads
need some help guys, i just finished up changing my heads, went to start the truck and it turns over but but wont start. ive checked everything that i disconnected atleast 10 times, any ideas.
btw, i installed stock heads
Old Nov 4, 2009 | 08:29 PM
silveradokidd_4518's Avatar
sure you got the grounds all connected?
Old Nov 4, 2009 | 08:31 PM
2000chevysilverado's Avatar
do the checks does it get fuel, power to spark, grounds and so on can be sumtn simple
Old Nov 4, 2009 | 08:35 PM
ss64impala's Avatar
i only remember disconnecting one ground, the one on the alternator.im getting no codes, but im not sure if im getting no fuel or no spark.
Old Nov 4, 2009 | 08:38 PM
if its turning the motor over but not starting i would start with the fuel just pull the number one plug out and put the end on the threads of the sprk plug hole and have someone start the truck for a second or two and can tell if your getn spark and fuel
Old Nov 5, 2009 | 09:01 AM
04SilveradoMykk's Avatar
See if you can spray starter fluid down the open throttle body while cranking (not the MAF), if it fires up but dies that will eliminate the fuel vs spark issue.
Old Nov 5, 2009 | 09:38 AM
ss64impala's Avatar
Thanks for all the info guys, but I think i know what the problem is. I will check this afternoon when I get home from work. I will let u know what i find.
Old Nov 5, 2009 | 09:40 AM
KMAN99's Avatar
There is a ground on the back of the motor, you shouldn't have to disconnect it to r&r the heads, but if you did that could be your crank no start issue. Like everyone else said i would def. check fuel pressure, spark tester is always a good cheap tool to have.
Old Nov 6, 2009 | 08:59 PM
ss64impala's Avatar
got her running guys, thanks for all the helpful info.
Old Nov 6, 2009 | 09:14 PM
A Low Dime's Avatar
13 Second Truck Club
What was it?
