My Truck has a bad problem i cant figure out.
Old Oct 4, 2016 | 03:56 AM
TombstoneAK's Avatar
Unhappy My Truck has a bad problem i cant figure out.
Ok lets start with what the truck is its an 88 chevy with a stock 350 tbi. The problem is it has a tough time starting and it idles like ****.It does stuff like dies when i come to a stop and then its impossible to get running again.The strange part is if i unplug the injectors it will fire right up than i plug them back in and the truck will at least run for a minute until it has a death cough at a stop sign and dies than there is no getting the truck running.I would appreciate any and all help.
-Thanks from Alaska.
Old Oct 4, 2016 | 04:09 AM
SLOPONY's Avatar
Try changing the coolant temp sensor for the computer, not the one for the gauge.
Old Oct 4, 2016 | 06:55 AM
darkirish63's Avatar
Nasty fuel filter?
Old Oct 4, 2016 | 06:58 AM
Wolftrk99's Avatar
How does the spray pattern look coming from the injectors? And do they leak?
Old Oct 4, 2016 | 07:25 AM
Shaggy2dope's Avatar
My 92 with a 350 tbi would start to struggle accelerating when I got on the highway. A fuel filter fixed it every time. I imagine if I let it go much longer I would have had the same problem you are having.
One time it started to struggle accelerating. I pulled into a convenient store and it refused to start up again. I pulled the air cleaner and cracked the throttle by hand. When it was healthy the fuel injectors would spray fuel when opening the throttle by hand. This time it did not. I replaced the fuel pump and that got her running again.
Try replacing the fuel filter. I bet a 6 pack that is your problem. Keep in mind you may be replacing a fuel pump soon as that filter is likely plugged.
Old Oct 4, 2016 | 10:23 AM
Wolftrk99's Avatar
The fuel pumps on those are only pushing something like 12-15lbs at most iirc, if the filter or an injector or clogged they dont have enough pressure to push fuel past it....
Old Oct 4, 2016 | 11:07 AM
tgui's Avatar
My dads 350 TBI Silverado when we lived in AK had the same problem. We got some **** fuel in Fairbanks with water and sediment. New fuel filter and all was OK.
Old Oct 4, 2016 | 11:53 AM
AkSSS's Avatar
ALL of the fuel in Alaska is ****! Just saying.
I'm not very familier with the obs 5.7's. I would start with a fuel filter like everyone said. Is the service engine light on at all?
Those motors would throw dtc's quickly it seemed like. Kinda odd that it would run with the injectors unplugged.
Old Oct 4, 2016 | 12:11 PM
Wolftrk99's Avatar
Running with injector unplugged typically means its dumping fuel
Old Oct 4, 2016 | 12:13 PM
Atomic's Avatar
I have a gauge for that
The fact you can start it for a second with the injectors unplugged means its flooded (too much fuel). As someone said, replace the coolant sensor. When that fails the computer reads -40F and injects a ton more fuel than needed at normal temp.
TrendSetter
Jan 15, 2017 11:56 AM
Albert Walters
Aug 14, 2016 11:59 AM
chevyboi925
14
Aug 5, 2016 06:47 AM
turboal1
Aug 4, 2016 11:05 AM
Mtm864
Jul 29, 2016 04:52 PM
