My setup
Old May 5, 2006 | 06:10 PM
closet red neck's Avatar
Originally Posted by jmproductions
It looks like you're planning on spinning that 5.3 up pretty fast with that setup! What about some upgrades to the valve train and rod bolts? And obviously you'll need a good tuner to get it streetable, but I do think it's possible. Other than that I can't wait to hear how she runs
All valvetrain will be upgraded and rod bolts........I'm still pondering on this one. Allen will be tuning this @ his house. I will be posting up soon.
Thanks,
James
Old May 5, 2006 | 06:15 PM
Dont ask me anymore questions ******!
No matter which way you go its still going to be chasing its tail running behind my truck.
Hey, don't get your mangina all up in an uproar!!!! I wanted to get some professional opinions!!!!LOL!!!! And no my truck won't be chasing your truck cuz I don't have to stop and put oil in mine very few hundred miles!!******!!
Have a nice day!!!
I'll call you later or you call me if you're not working or sleeping.
James
Old May 5, 2006 | 10:28 PM
Originally Posted by bluecajun5.3
sounds like a different but interesting combo for a 5.3. once that thing is tuned it should be a beast. i'm anxious to see what it puts down. good luck with the build, it should be a good one.
Thank you sir!! It will be this summer for sure.
James
Old May 5, 2006 | 10:35 PM
Originally Posted by vanillagorilla
I say you mill a little off those heads to get the SCR up a bit. That's assuming you stick with the stock 5.3 short block. I don't think you'll have PTV clearance problems since the pistons are dished. I would think you'd need at least a 4000stall and I vote for the 4.56's, but it depends on what tire size you'll be running.
Oh yeah, how "built" is your 60E?
Flyer had a big hairy cam like that in his 5.3, you might want to PM him on the tuning details.
How much do you think I should mill the heads??? I'm going to stick with the 1.7 ratio. I'm probably going to get the 4000 and the 60E is built!! The thing with the gears is that when this thing is finished, I'll go and get some times on it and thats it. So with that being said I'll run a 26" tall tire @ the track and see what times I get and if I'm not happy, then I'll put some more gear in it. With the 3.73's in it now and a 26" tire it'll be close to a 4.10:1 gear(I think).
James
Old May 6, 2006 | 01:25 AM
sounds like a pretty sweet weekend warrior IMO. next you will find yourself wanting some spray!
Old May 6, 2006 | 12:27 PM
Well, I'm trying not to go that route!!!! But 1slow01Z71 is a bad influence on me!! I might before it's all said and done. Maybe one time @ the track to get a time slip.
James
Old May 6, 2006 | 03:17 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Old May 7, 2006 | 12:20 AM
when its a weekend warrior its al abotu the time slip...what does a 200 shot hurt anyways?!....
Old May 7, 2006 | 12:26 AM
Awesome setup! And as for mileage, I bought my 06 in August and only have 2,600 miles on it...
Old May 7, 2006 | 12:33 AM
Ross @ EDO's Avatar
FormerVendor
I hope that setup works out better for you than it did for me.
