my new project!!!!!!!!!!!
Old Jul 25, 2004 | 08:45 AM
one03sierra's Avatar
Formerly one92rs
Talking
1.i havent figured out where i am going to run the purge.i am stuck between out from the cowl hood or up the windshield.
2. NX stage 1 #20920 for chevy fuel injection-NX purge kit and gauge.
3.bottle warmer will be ordered soon
4.wiring is to be run in the next few days.i was planning on running the wires down to the speaker inlet on the pass side and in to my center console.
5.yes the line on the right is the fuel feed line.and yes it is long enough for it to go to the throttle body--another story--or to the intake tube if i want with thefeed lines.
6.bottle is mounted in the bed on the passenger side and the line is routed along the frame rail. pics will come soon.
7.i do not have a window switch yet.right now i am going to use a TCI trans brake switch to activate it.i am going to see if i need to back off timing and if i do or dont want to run it during 1-2 shift.my plan is to find out about timing- and shifting. i want to get a timing tuner and have it shut off when in the 1-2 shift and then come back on and stay on. i also need to figure out my launches since i dont have slicks also. i think i want a delay when launching.so right now i am going to do it manually till i figure it all out. then i will get a controller to suit my needs if i need one.
as for the line--look under the truck on the passenger side.where the cab and bed mount to the frame.there are the mounting brackets for the bushings. each one has a slot in it.that is where i ran the line.i did this to keep it from the exhaust and muffler which occupy alll my space inside the frame on that side.
Old Jul 25, 2004 | 12:53 PM
Onyx 02's Avatar
Damn, You should be in the 13s now!!! I can't wait to see it run at HRP.
cheyenne383
Nov 13, 2015 09:24 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
vipergtrdj
Sep 11, 2015 05:52 PM
