My Nelson fan harness is eating relays
Old Jul 14, 2006 | 10:07 AM
  #21
moregrip's Avatar
what a rush!
Originally Posted by thunder550
What did you swap them to?
forget the brand name, I'll look today if you still need me too. I believe BC switched to Bosch relays as he experienced the same thing.
Old Jul 14, 2006 | 10:47 AM
  #22
thunder550's Avatar
High on diesel fumes
Originally Posted by ltn
do u have a lower tstat?
Yes, I have a 160.
Old Jul 14, 2006 | 10:48 AM
  #23
thunder550's Avatar
Yes please, that would be great
Old Jul 16, 2006 | 09:03 PM
  #24
moregrip's Avatar
what a rush!
looks like I used Bosch too
Old Jul 16, 2006 | 10:47 PM
  #25
thunder550's Avatar
Thanks!
Old Jul 16, 2006 | 11:13 PM
  #26
BlownChevy's Avatar
blownerator
25 Year Member
Mine at an alt. today. I have noticed that the constant on and off cycle with the A/C has been causing a serious current draw on the charging system. Looks like this may need another look see to make this harness better.
Old Jul 17, 2006 | 01:00 AM
  #27
thunder550's Avatar
I was trying to find out if there was any kind of time-delay relay that could be installed to keep both fans from turning on at the same time. Maybe trun one fan on then the other a couple seconds later, or find something that gradually ramps up the fan speed.
Old Jul 17, 2006 | 01:03 AM
  #28
moregrip's Avatar
what a rush!
I was also thinking, since I have an 05, I wonder if the circuitry is there to just plug in the stock wiring/stuff, activate it in the PCM, and be good to go. thoughts?
Old Jul 17, 2006 | 01:25 AM
  #29
thunder550's Avatar
I think it is, might be worth doing some research since I think the fans are supposed to be variable speed in OEM applications.
Old Jul 17, 2006 | 05:14 PM
  #30
BlownChevy's Avatar
blownerator
25 Year Member
installed the 145 amp today, seems to be a little better on the draw.....
we will see.
GM part# 10464476
I noticed that one ONE fan is on with the A/C turns on if the temp is below where it is set to come on....does that make sense? LOL
