My 5.3 to 6.0 swap
Old Dec 16, 2010 | 05:21 PM
  #21
Country Boy's Avatar
Senior Member
Originally Posted by Dezert1500
That's just how FelPro makes the replacement exhaust manifold gaskets. If you want the MLS gasket you run a GM one. The FelPro ones work great and don't blow out like old cork type gaskets. I've run both MLS and FelPro, both work great and I've had zero exhaust leaks with both.
Torque from the inside out, alternating and make two passes. I forgot the specs off the top of my head.
18lb ft.
Yea, that just how they make theirs. Ive used them and the stockers with no problems. just do NOT use the paper gaskets. They will blow out. Been there.
Old Dec 16, 2010 | 05:27 PM
  #22
brandon_6667's Avatar
cool since i already have them i might just use them instead of reusing the mls gaskets.
what about the head gaskets? obviously they arent reuseable but what about getting felpro head gaskets? they are MLS and look identical to the GM gaskets but are a little cheaper. only like a $10 difference so if theres any doubts i will just get the gm gaskets.
one more thing, should I stick with factory GM head bolts or would the sealed power or rock products brand work just as good? they are TTY and look identical as the factory ones but im just asking about them and the felpro gaskets because im looking to buy it all at once and thats what rockauto carries, and they seem to have the best prices for the non-GM stuff.
Old Dec 16, 2010 | 05:53 PM
  #23
Senior Member
Theres nothing wrong with using aftermarket parts. It will all be just fine. They are all probably the same bolts. Theres only a manufacturer or 2 that make the parts and just sell it to different companies that put their name on it.
Old Dec 16, 2010 | 06:07 PM
  #24
thats what I was thinkin but wanted to hear it from someone with experience, thanks!
Old Dec 16, 2010 | 07:49 PM
  #25
Senior Member
waaaaaaay too much unfortunally.
Old Dec 16, 2010 | 10:34 PM
  #26
StrokerAce03's Avatar
If the bearings look fine, Id just keep it together and call it a day. I dont *think* the mains and rods are TTY so Im pretty sure they are reusable. When I built my last motor, I used all ARM hardware.
The two side bolts on the main caps are TTY, the other four are reusable.
Old Dec 17, 2010 | 02:22 PM
  #27
I'm having a hard time locating replacement side bearing cap bolts. Anyone got a link?
Old Dec 17, 2010 | 02:47 PM
  #28
baSICK5.0's Avatar
you re-used them or just bought new ones identical to the old?
yes literally re-used the actual original ones. No issues whatsoever. But course i made sure they werent bent or anything.
Old Dec 20, 2010 | 12:15 PM
  #29
So i popped the all the main bearing caps except the rear cap and they all look exactly the same. You can see lines on them but they feel smooth to the touch and there is no discoloration in any way on any of them so as far as I can tell by visual inspection and to my knowledge they seem to look ok but I would like some input on if they do look normal.
So if they are fine I'm going to order the new side bolts, head bolts, etc after xmas and will be finally putting it all back together and waiting for a sunny weekend to throw it in the truck.
Heres a couple pics. let me know if anything looks odd that i'm not seeing. these aren't pics of every bearing but they all look exactly like these
Old Dec 23, 2010 | 01:44 PM
  #30
Anyone think these look bad??
