my 4" exhaust
Old Oct 21, 2009 | 08:12 AM
silver-mod-o's Avatar
Hunt&Fisherator
Default my 4" exhaust
I have had a few requests for pics of my exhaust setup... I know the pics arent real great but you get the idea...
feel free to ask if you wanna know details. Its a real simple setup, but it works.
Old Oct 21, 2009 | 08:14 AM
04SilveradoMykk's Avatar
Looks good, never seen a 4" single on a gas motor. I've got a dual 3" w/ H-pipe.
What are those traction bars?
Old Oct 21, 2009 | 08:19 AM
Hunt&Fisherator
I know a few guys who run a 4" single with nitrous setups. Mine happens to be a turbo setup. The system is a Jegs brand turboback with a VERY unrestrictive muffler, and it exits in the stock location Originally built for a Duramax, which is probably why it fits pretty well under the truck, nothing hangs below the frame anywhere.
Old Oct 21, 2009 | 08:32 AM
lownslo's Avatar
Does the long straight pipe curve back in after going around the x member or does it go straight back over the axle?
Old Oct 21, 2009 | 08:36 AM
Hunt&Fisherator
it angles back toward the axle and goes over, and out...
Old Oct 21, 2009 | 08:40 AM
BlackGMC's Avatar
Resident Retard
How is the tone/sound? Looks like it should flow well, no major bends and it looks mostly straight.
Old Oct 21, 2009 | 08:54 AM
Hunt&Fisherator
well from the turbo outlet its a 3" downpipe back to right about the trans crossmember, then from my cutout it goes to 4" the rest of the way back... you can pretty much stick your arm through the muffler LOL, as far as restriction goes, I dont really think there is any LOL.
It is VERY low, deep toned, smooth, mellow sounding, but not quiet. I really like how it sounds. I have a track vid floating around the Tx section of it. You can hear the turbo through it loud and clear. Even at idle. Who needs an STS for the whistle
Old Oct 21, 2009 | 08:56 AM
Hunt&Fisherator
those are the long bars I built. The worked for the wheel hop but never could get them setup correctly I guess... I took them off last night, and currently looking at other options. probably build a shorter, cal-trac type bar in the near future for it.
Old Oct 21, 2009 | 09:07 AM
Post an exhaust/drive by vid!
Old Oct 21, 2009 | 09:38 AM
LsxCody's Avatar
Did you have to modify the exhaust to fit
