my 4" exhaust
Old Oct 21, 2009 | 10:00 AM
charcold-bowtie's Avatar
Answer your dam phone sometime ben
mines simliar, except right here, it fit through the frame work, so mine a straight joint of 4inch, with a little crick at the muffler. There may be a little crick at the DP connection. But I didnt find a good deal on a duramax exhaust either.
this is my old 3inch, but the four inch runs the same with no bend. and the diesel magnaflow is still there.
Old Oct 21, 2009 | 10:08 AM
quicksilverado's Avatar
Originally Posted by silver-mod-o
well from the turbo outlet its a 3" downpipe back to right about the trans crossmember, then from my cutout it goes to 4" the rest of the way back... you can pretty much stick your arm through the muffler LOL, as far as restriction goes, I dont really think there is any LOL.
It is VERY low, deep toned, smooth, mellow sounding, but not quiet. I really like how it sounds. I have a track vid floating around the Tx section of it. You can hear the turbo through it loud and clear. Even at idle. Who needs an STS for the whistle
Mine is similar to yours. 3" of the turbo and steps up 4" with a 30"straight thru muffler. It is a ittle loud for my taste. When I lay into the gas it seems to get quieter. You can't hear the turbo unless I get on it.
Old Oct 21, 2009 | 01:04 PM
nonnieselman's Avatar
Bens truck sounds similar to a Fbody with a hint of Whistle.. it sounds wicked, but still pretty quiet in the cab.
Old Oct 21, 2009 | 01:34 PM
lownslo's Avatar
This is pretty much what im installing on my truck this afternoon. I hope it sounds good....right now you cant hear any whistle at all from the exhaust.
Old Oct 21, 2009 | 02:24 PM
silver-mod-o's Avatar
Hunt&Fisherator
I'd really prefer there not to be any turbo noise from the exhaust, but I'd give up a ton of flow to make that happen, so I figure I'll deal with it. I havent got a single race since its been back on the road I think they scurred between the pillar guages and the crazy souding exhaust LOL
Old Oct 22, 2009 | 02:38 PM
Nicksilverado's Avatar
hell ill give ya a run ben! i might get my eardrums blown out from the sewer pipe your running under the beast though .ha!
Old Oct 22, 2009 | 03:49 PM
camochevy21's Avatar
Do you have any vids of what it sounds like?
Old Oct 25, 2009 | 12:39 AM
ryan_prettyman's Avatar
Banned
I did alot of searching for 4" diesel exhaust kits and the best price, I found with a little bit of modifying is the magnaflow kit. Mine is a 1/2 ton crew cab and the kit for the 2500 crew cab regular bed is only $339 from summit, all stainless no tip though probably what I will use with my turbo kit, my t-70 has a 3" outlet so I will need to get a reducer however if I ever upgrade to the GTK 850 it already has the 4" outlet anyways, you guys should checkout the magnaflow kit!
flatblack83
Jan 3, 2026 07:10 PM
kha4079
Oct 29, 2018 04:38 PM
blown02408
Feb 24, 2016 04:50 AM
gaps
Oct 15, 2015 02:53 PM
Superman09
Sep 25, 2015 05:55 AM
