Mufflers that won't drone
Old Apr 20, 2015 | 09:37 PM
tboy22's Avatar
Default Mufflers that won't drone
I have a 2014 Sierra with the5.3 and looking for a muffler that won't drone bad when the engine kicks into v4 mode but still has a good sound to it. Also when I get the muffler should the resonator be removed? Possibly looking at magnaflows as well as the corsa db muffler
Old Apr 20, 2015 | 10:15 PM
nlawson6.0's Avatar
im also looking, my mbrp is a no go.
I have a 14 5.3 that has arh headers with a 6.2 y pipe with cats for the 3.5 flange with a full 3.5 mbrp and the drone is the worst i have ever heard, it sounds like the windows are goin to blow out and u get a instant headache. The sound outside the truck is great, and exactly what i wanted.
-Nate
Old Apr 20, 2015 | 10:53 PM
RS/SS 4.8's Avatar
10 Second Truck Club
If you want less drone do not remove the resonator.
Old Apr 21, 2015 | 12:07 AM
gamble686's Avatar
Need to get a magnaflow big body and make a resinator tube for it.
Old Apr 21, 2015 | 01:06 PM
FlowmasterMufflers's Avatar
Former Vendor
^^^This is excellent advice. Also, keep muffler case size in mind when making your decision. In general, a larger-case muffler will be less aggressive and produce less noticeable drone. Find the sound that you like and then figure out which muffler will fit your application and meet your requirements.
Old Apr 21, 2015 | 01:28 PM
TXsilverado's Avatar
I want mine to sound like a top fuel dragster outside, but a prius inside...what should i get?
Old Apr 21, 2015 | 03:20 PM
01silvy's Avatar
^^^^^HAHA.... You will be looking for awhile.
Old Apr 21, 2015 | 05:08 PM
FFDP's Avatar
Install big boombox speakers on the outside of your prius, then play racecar noises.
Old Apr 21, 2015 | 06:05 PM
tboy22's Avatar
What about the corsa's because they have a good sound to them for sure but they are a bit pricey
Old Apr 21, 2015 | 08:49 PM
Corsa is the best option for a drone free exhaust. If you plan to keep oem manifolds and y with converters, grt the sport. If you want longtubes and ory, get the touring and add a short bullet style muffler inline.
My hd had the biggest dual in/out muffler magnaflow makes and it sounded very nice with no drone.
