Muffler Replacement
Old Sep 5, 2003 | 07:01 AM
Default Muffler Replacement
Is there a muffler that is a direct replacement for the factory one on a 2500HD 6.0? Something that would offer an increase in performance, but without resonance and drone. It seems a shame to remove all that large diameter stainless steel pipe and replace it with new piping just to get a muffler with a new cat-back.
Thanks,
Mark
Old Sep 5, 2003 | 12:57 PM
Default Re: Muffler Replacement
Corsa
Old Sep 5, 2003 | 12:59 PM
FILE's Avatar
What size of pipe is that. Magnaflow makes this muffler that is 22 inches long. It almost sounds stock and you get a nice encrease in performance.
Old Sep 5, 2003 | 02:11 PM
I believe Magnaflow and Flowmaster have a direct replacement muffler for the HD muffler.
Jim
Old Sep 5, 2003 | 02:17 PM
Banned
if all you want is a different muffler for your stock one just have it cut out and replace it with something with an inlet and out size the same as the stock muffler. SIMPLE ISN'T IT?
Old Sep 5, 2003 | 02:18 PM
Banned
better yet, get 2 dynomax bullet mufflers welded to the dual pipes on the outlet of the stock stuff then a Y at the front and mate it into where the stock stuff was. kinda sounds weird but it would work
Old Sep 5, 2003 | 03:33 PM
The stock muffler is 25" long with dual inlets/outlets. Not sure of the sizes, but I think the inlets are 3" and the outlets are 2 1/2". NOT SO SIMPLE, IS IT?
Old Sep 5, 2003 | 03:39 PM
Yelo's Avatar
The stock muffler has a single outlet that is 2.75" and dual inlets that are 2.75".....the ONLY muffler I have found that is a true stock replacement is from Flowmaster.....it is a dual 2.75" in/dual 2.75" out 50 series SUV muffler
Old Sep 5, 2003 | 04:07 PM
FILE's Avatar
Ok.. you might want to try this muffler from Magnaflow. The part # is 12579. This particular muffler is 22 inches long and has a 3 inch inch in and out. It should work great for you truck.
Here is the their page... .
http://magnaflow.com/02product/universal/oval.htm
Old Sep 5, 2003 | 04:27 PM
Need dual in/out. I'm gonna take some measurements and have Spin Tech make one. If the Flowmaster was stainless, I'd consider it, but all I an find is aluminized steel.
Fast86z
Aug 23, 2015 12:35 AM
FlowmasterMufflers
Aug 17, 2015 04:44 PM
thewrx
Aug 12, 2015 08:28 PM
