Motors knocking, running rough and 235lbs on 7.
Old 02-28-2011, 08:45 PM
dirt track racer 81's Avatar
Default Motors knocking, running rough and 235lbs on 7.
My 370 started knocking the other day and acting like its running lean, hesitant and popping and not running as usual. All the plugs look good and look the same, all the cylinders had 190-195 lbs compression except for 7 that had 235lbs!! I tested it 4 times and everytime it was 235lbs. All tests were done with the fuel pump relay disconnected with the throttle wide open. Its got l92 heads milled .030 with Comp OE lifters. 244/248 .612/.615 cam, 7.35 pushrods. Next up I'll try a leak down test and if can find one. My first thought was possibly a collapsed lifter on the exhaust, not letting exhaust out and its coming from that general area. Any other thoughts?
Old 02-28-2011, 08:52 PM
Hunt&Fisherator
silver-mod-o's Avatar
some sort of debris in the chamber?? have you borescoped the plug hole?
amadeospike's Avatar
turn the motor and look at the springs for that that cylinder. if its collapsed u may be able to see it doesnt move. if the valve is not opening you'll definitly get that popping
Old 03-01-2011, 11:14 AM
Camaro Zach's Avatar
I broke a few springs one day and had a similar issue. Never checked compression though. Pull the valve covers off and see what you find. #7 was the first one of mine to break
Old 04-18-2011, 02:01 PM
Notorious BIG
Holty's Avatar
Tyler, ever figure this out? I'm having a similar issue, but no knock or misfire codes. Although, my compression test also shows all cyl's at 150psi.
OHsixLS3
12-27-2016 09:30 AM
stealthperf
34
02-14-2016 11:35 AM
BennyB
08-01-2015 08:48 AM
jmarkway
07-18-2015 09:23 PM
Quick Reply: Motors knocking, running rough and 235lbs on 7.
