Which Motor
Old Aug 9, 2004 | 08:47 AM
Barely Boosted's Avatar
Default Which Motor
Plain and simple for best hp by not tearing all the way down vette ls6 motor or 6.0.
Old Aug 9, 2004 | 09:35 AM
wow that's a good question. I persoanlly wsould go with the ls6 but they suaully cost quiet a bit more. You will save around 90lbs off the front. But for the $$ usually the 6.0 is the better way to go. youcan swap in a cam and springs while the engine is out and You will be producing a really nice healthy number.
Old Aug 9, 2004 | 09:43 AM
Scream's Avatar
MOOBIES Moderator
I went with an aluminum motor to save weight. Between those two, I would pick an LS6 over any 6.0, unless you're planning on running any serious amounts of boost later on down the road.
Old Aug 9, 2004 | 05:43 PM
thanks but how much boost is too much.
Old Aug 9, 2004 | 06:45 PM
GMCtrk's Avatar
ls6 for sure
Old Aug 9, 2004 | 08:05 PM
GMC SKI's Avatar
You can get away with 10-12 Psi on a stock 6.0l for a while with a good tune and running it richer than normal for safety
The Ls6 Aluminum block has higher compression too and you should be able to live with 8-9 psi just because of the added compression
I went Iron and am running 15psi on Pump gas with a turbo
Old Aug 9, 2004 | 08:12 PM
If i changed the heads would it lower the compression if so where could i buy some?
Go5.3tt06
25
Sep 4, 2016 10:25 AM
Glenn98ZM6
Sep 18, 2015 07:31 PM
dantheman1540
Sep 18, 2015 03:03 AM
03chevytruck
Sep 14, 2015 09:15 PM
