Monitoring Trans and Engine oil temps
Old Mar 8, 2006 | 08:44 PM
TurboGibbs's Avatar
Around $200 is what I gave for mine. You have to hard wire one 12v switch power wire and the other just plugs to the diagnostic port.
Old Mar 8, 2006 | 09:18 PM
treyZ28's Avatar
Originally Posted by 99Silver6.0
The gauge is only $230 shipped.
I cant watch oil and trans at the same time with that.
Old Mar 8, 2006 | 09:22 PM
TurboGibbs's Avatar
you can watch 2 parameters at a time with the interceptor scanguage. You can actually set it up to record those 2 parameters. It will start recording when it see's >50% throttle. This is handy for me at the track to see IAT's. It is also handy if you want to see your mph if your guage only goes to 100. The advantages of it are almost endless.
Old Mar 9, 2006 | 03:45 AM
Post
Actually you can. It displays more than one output function at a time.
The 12v power can easily be added with an add a circuit from your local parts house.
Jim
Old Mar 9, 2006 | 03:53 AM
TurboGibbs's Avatar
Did you know you can view 2 different parameters at one time?
I am not sure if your engine has an oil temp sensor on it though. If it doesn't you won't be able to see it on the scanguage of course, even if you add one. The scanguage sees basically ever sensor that inputs into your computer.
Also, you can view more than one thing at the same time with it.
ferrellrooster
Mar 6, 2025 03:22 PM
ullose272
Aug 5, 2016 02:05 PM
Noah Burns
Sep 7, 2015 05:50 PM
ullose272
11
Jul 17, 2015 07:22 AM
Nimoryan
Jul 5, 2015 03:50 PM
