Monitoring Trans and Engine oil temps
Old Mar 7, 2006 | 04:59 PM
treyZ28's Avatar
Default Monitoring Trans and Engine oil temps
Aside from using a denali gauge cluser, what is the best way?
Can I tap into the existing pcm/OBD sensors?
Old Mar 7, 2006 | 05:01 PM
TurboGibbs's Avatar
I'd get an Aeroforce Interceptor Scan Guage. It shows everything + pcm codes and clears them.
Old Mar 7, 2006 | 05:49 PM
Thumbs up
The Aeroforce gauge does seem like a pretty unique gauge.
Allen Nelson recommended that gauge when I asked about different gauges.
www.aeroforcetech.com
Jim
Old Mar 7, 2006 | 11:09 PM
treyZ28's Avatar
$329? Id rather just get a full tuner for another $150.
I really just want to see trans and oil temp when I'm towing.
Old Mar 8, 2006 | 09:37 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
That is an excellent gauge -- you can monitor almost anything you want without taking a laptop everywhere, and it resets codes on the fly.
Old Mar 8, 2006 | 10:20 AM
LS1TRUCKGUY's Avatar
Is The Guage Plug & Play, Or Do You Have To Hard Wire It?
Old Mar 8, 2006 | 10:36 AM
Nick™'s Avatar
you could add a double gauge pod on your A-pillar, tranny is simple enough, for the oil temp you may have to get creative like getting an aftermarket oil cooler so that you can access your oil for a reading without putting a sender in the pan..... tuning programs don't give tranny and oil temps.
Old Mar 8, 2006 | 12:18 PM
I AM A MOTHERF*CKER
The aeroforce is plug-n-play to the obdII port.
Old Mar 8, 2006 | 04:11 PM
shandy294's Avatar
The gauges should come with a driving device (transducer?) or tell you where to tap into.
Old Mar 8, 2006 | 06:44 PM
99Silver6.0's Avatar
The gauge is only $230 shipped.
