Money To Spend, What Next? Help Guys!
Old Dec 29, 2003 | 07:40 PM
dowright82's Avatar
Default Money To Spend, What Next? Help Guys!
Setup As of Now:
Regular Cab Stepside 4.8 Liter 5-Speed with headers, FIPK II, MAF Sensor, Diablo Predator, and 3.73 Eaton Posi Rear. 160 Thermostat, Flowmaster 2 3/4 "
My question is this: What next?? I've got 67k miles on it, and never use anything but mobil one oil, and I have been considering a supercharger, or this new turbo kit I've been hearing about, but I'm concerned about the longevity of my soon to be tired motor.
I'm leaning towards the NA route, but I don't know much about motor work PRICES. I'd like to put a different cam in it, some new heads, and perhaps stroke it out for some more cubes, but I can't decide what to do first, and in what order.
Also, I have considered just going for it, and doing the same swap another guy on here did, the 6.0 Liter + 6-speed tranny. I've only got about $4000 thus far, what do you think???
Any advice whether minor mods I'm missing or Major ones, let me know - I'm still running factory plugs at factory gap specs with factory wires . . .
Any help would be greatly appreciated . . .
Old Dec 29, 2003 | 07:59 PM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
Nitrous and a built tranny
A built engine will get very expensive. I would just go with a stock 6.0 (~$1500 used) and a built tranny(~$2500) if you want to be conservative about it. Throw some nitrous on there...then you will definitely need a built trans.
Old Dec 29, 2003 | 09:27 PM
mudz5.3's Avatar
You could do a 6.0 swap, mild cam. I think as far as the 5 speed goes, either 6 speed and some 4.10's in the back or for cheapness, I think you can replace the man trans input shaft for a lt1 input shaft. Not sure if there the same with 5sp or 6 sp but I doing that with the 6 speeds will work, should on the 5's. The lt1 input shaft is stronger supposedly. Might want to think about a clutch if you build that 6.0. Most of all, have fun and keep posted.
Old Dec 29, 2003 | 09:30 PM
mudz5.3's Avatar
Ok, just read your other post, didn't know the mans where nv's. I wonder if the nv4500 would fit? Really good man trans, I think first might be too low though. Have to check numbers.
BKnBLK05
Dec 28, 2015 08:52 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
