Mobil 1 5w or 15w?
Old Aug 20, 2004 | 02:40 PM
Carrotop79's Avatar
Default Mobil 1 5w or 15w?
Hello all, just wandering about oil for the Yukon. I have been using M1 5w-30, but I have seen the red capped M1 15w-50. I live in SE Alabama and in summer we get approx. 90-100 degrees and in the worst winter maybe a week or two in the low 20's. Is the 15w okay for me to use?
Old Aug 20, 2004 | 02:49 PM
Evil 99's Avatar
15w50 motor oil means that at 32 degrees the oil has the properties of a 15 weight oil and at 200 degrees has the characteristics of a 50 weight oil
Old Aug 20, 2004 | 02:50 PM
budhayes3's Avatar
PT's Slowest Truck
Personally, and this is just my opinion, I'd stick with the 5w for a couple of reasons. First, that is what the manufacturer recommends, and second, the first number is what the oil's characteristics are cold. Once the oil heats up to a certain temperature, it takes on the characteristics of a 30 weight oil. But that's just me.
Just realized that you were considering 15w-50, I was thinking 15w-30. I definitely don't see any reason you'd need a 50 weight unless your engine is on it's last leg or you've got some major HP and are taking it to the extremes. Once again, just ny opinion.
Old Aug 20, 2004 | 02:53 PM
i would run either 5 w 30 or 10 w 30 their is no reason for you to run 15w 50 IMO.
Old Aug 20, 2004 | 03:00 PM
Tokez420's Avatar
10w30 here in southern cali
Old Aug 20, 2004 | 03:02 PM
The manufacturer recommends 5w-30 for gas mileage reasons, nothing else. You can run a 15w50, but it is a little unnecessary. In your climate, you should run a 5w30, 10w30, etc. in my opinion.
Ryan
Old Aug 20, 2004 | 03:07 PM
10w30 M1 - here
Old Aug 20, 2004 | 03:13 PM
OBXMarine's Avatar
I did alot of reading up on the subject before I made the jump to synthetic. I went with Mobil 1 0W40 2 days ago. I think the Mobil 1 10W30 thins out to a 20W in our motors. Do a search for oil or for our resident oil guru, Patman.
Old Aug 20, 2004 | 07:10 PM
blk03's Avatar
Originally Posted by LS1csherm
10w30 M1 - here
same.
Old Aug 20, 2004 | 07:50 PM
chevymec's Avatar
5w30 Mobil 1 here in N.C. Still have 45 psi of oil pressure at operating temp year round.
