Missfire after header install/2000 chevy silverado 5.3
Old Jan 18, 2017 | 12:25 AM
5.3californiachevy's Avatar
Registered User
Default Missfire after header install/2000 chevy silverado 5.3
I have just recently installed long tube headers on my 2000 Chevy Silverado I still have the EGR valve hooked to the header but a vacuum line and another egr looking peice for smog I pulled apart not thinking that would cause a problem, the truck is throwing no codes but is missfiring, all cylinders are firing off and each header pipe is warm but it had a rough idle and drives like crap, the o2 sensors are pluged in and everything but could anybody give me some strong info?
Old Jan 18, 2017 | 07:15 AM
Drspencer's Avatar
5 Year Member
When were the O2's replaced? Is the MAF plugged in. You can try spraying some water (Spray bottle, not garden hose) around the intake to see if it changes idle. That can grab a vacuum leak.
Old Jan 18, 2017 | 07:55 AM
wretched73's Avatar
Check spark plug wires. Make sure none of them touched and burned through. And also that you put them on all the way
Old Jan 18, 2017 | 09:14 AM
GM1697's Avatar
Torched wire for sure.
Old Jan 18, 2017 | 09:42 AM
BigKID's Avatar
Cracked plug(s) from header installation
OR
Unmetered air from "vacuum line and another egr looking peice for smog I pulled apart not thinking that would cause a problem"
Old Jan 18, 2017 | 11:40 AM
Registered User
Could a bad o2 sensor cause a missfire?
Old Jan 19, 2017 | 11:01 AM
2KRedSilverado's Avatar
It could. Or it could just be giving a bad reading I think.
Did you check all the wires/plugs?
Old Jan 19, 2017 | 12:31 PM
darkirish63's Avatar
OR
Cracked plug happened to me when my LTs where put on - take each one out and check the porcelain. Doesn't take much to crack one when a header bumps in to it on install.
Old Jan 20, 2017 | 10:47 AM
terravast4's Avatar
i was doing my install and tried to rush it because it was getting dark. finally got it al done and was excited to go go test drive it and it ran like ****. when i got back i had two burnt wires and half the wires were not even pushed in all the way. in my mind i thought i checked everything. sometimes we get in a rush and forget things
