Misfire headache
Old Feb 15, 2008 | 02:45 AM
joeyc125's Avatar
11 Second Truck Club
Default Misfire headache
Hey all, i just put a set of pacesetter lt's and ory ony my truck last week, while i was at it i put in a set of ngk tr55 plugs. Well i was running it with my stock pcm while wheatley was retuning it for the headers and this thing was running like @$$. It was missing a little at idle and when you give it gas, usually not while at WOT. I thought it would clear up with the other pcm which it did, for about 75 miles then it slowly came back. Ive checked everything i can think of, coil plugs, new wires, injector plugs, made sure wires were on tight, ive always ran a can of sea foam at every oil change so the fuel system should be clean, im about to run this thing into a tree im so frustrated, ive tried all week. Also i am getting codes 0300- random misfire, 0141-61 rear 02 heater circuit, which i thought charlie would tune out but he must of forgot. ANY IDEAS??? P.S. sorry for the longwindedness!! Thanks!
Old Feb 15, 2008 | 06:20 AM
lady3bglover's Avatar
I can tell what happened to me when I had the misfire...it turns out the #7 wire was getting toasted by the new headers, so I changed all of the wires out and found these wire insulators that cover up to 1200 degrees. Since then never had a problem.
http://cableorganizer.com/insultherm-spark/
Lisa
Old Feb 15, 2008 | 06:39 AM
ap2002's Avatar
did you drop a spark plug when you were changing them out? if you drop one and it cracks, you'll have these problems as well...
Old Feb 15, 2008 | 12:31 PM
joeyc125's Avatar
I changed the wires after the headers were done, about 100 miles thinking i broke a wire during the install, same problem instantly. When i put charlies tune back in yesterday it ran great for about 75-100 miles then it progressively came back???? And thanks for the help!!
Old Feb 15, 2008 | 12:33 PM
joeyc125's Avatar
O and don't ask why but today i added about 4 gallons of 110 to 3/4 tank and after about a mile or so it got better and now running perfect?? sure not spending $5 a gallon to drive my DD. Cant figure what the 110 would do besides if there was too much timing, its a stock motor. EDIT running like @$$ once again... Im at wits end im gonna try replacing the tr55 with some new stock ac iridiums. Its a random mis, code 0300 its not cylinder specific.
Old Feb 15, 2008 | 01:49 PM
00ChevyScott's Avatar
Wearin' da big hat
maybe wheatley tuned it for 93 instead of 91? Idk that seams like too much of a rookie mistake for him...
Old Feb 15, 2008 | 04:51 PM
TURBHOE's Avatar
what is the gap at on the plug? are there any exhaust leaks around where the heads and headers meet? do you have any way to data log? a exhaust leak could make your o2's think they are lean and add to much fuel. just some ideas to think about.
Old Feb 16, 2008 | 05:27 PM
joeyc125's Avatar
Well problem solved. It seems my truck did not like the tr55's too well, i have heard to gap them anywhere between 35-60 thou so i had them at .050. I swapped them out for some new oe ac iridiums, and it purrs like a kitten now, no misfires whatsoever. Those of you running tr55's, what are you gapping them at, and why do you choose them over the acdelco's? Thanks for the replies i know i am somewhat new on here but i try to help if i can.
Old Feb 16, 2008 | 06:04 PM
fastgmc53's Avatar
14 Second Truck Club
I have had problems with the ngk's Also now I just use AC Delco double platniums
Old Feb 16, 2008 | 07:56 PM
Wheatley's Avatar
Truck Sponsor
Great to see you found the problem.
