milling 243 for a 5.3
Old Dec 13, 2011 | 08:05 PM
TheRepairMan's Avatar
Banned
Default milling 243 for a 5.3
i was wondering, whats the max i can mill a set of 243 heads on a 5.3 with a tsp224 cam, before having issues with PTV clearance, and race fuel.
Old Dec 13, 2011 | 09:13 PM
lsxnation's Avatar
Banned
I Mill mine 0.030 , but I've seen people mill them 0.055 on a 113 lsa 224R on a flat top piston
Old Dec 14, 2011 | 06:50 AM
Banned
i have 112 lsa, with 581 lift. i wonder if i would be okay will going .040
Old Dec 14, 2011 | 12:00 PM
afsp1211's Avatar
Keep in mind that if you get them milled too much you'll have to mill the intake mating side as well for proper sealing.
Old Dec 14, 2011 | 02:51 PM
05gmcsierra's Avatar
i milled mine .030 with a 222/226 596/598 111+2lsa cam with no issues.. got my compression to 10.5:1.. i think thats should b enough for that cam do act like a beast.. im on a flat top piston l33 engine if ur on a dished piston mill them .040 so u gain a bit on the compression side if not .032 will get u back to 9.5:1 which is stock
Old Dec 14, 2011 | 03:13 PM
Banned
i wanna bump up the compression quite a bit. im thinking about milling them 50thou . what size head gaskets are you guys using ?
Old Dec 14, 2011 | 06:59 PM
afsp1211's Avatar
If you're wanting to bump compression go with either .045 or .051. Milling .05 on the heads I'd check and see if you'll need to take any off the intake side.
Old Dec 14, 2011 | 08:43 PM
dmelvin's Avatar
Mine are milled .030 and I used a .040 head gasket. My CR is right at 9.9:1
Old Dec 14, 2011 | 09:15 PM
Banned
how do i go about measuring the intake side to see if i need them milled or not ?
Old Dec 17, 2011 | 06:09 AM
Banned
what kind of gains am i going to see going from 706 heads to milled 243 heads
03regcab sierra
Sep 9, 2015 02:02 PM
Boyes50
Sep 6, 2015 05:31 PM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
06 4.8
Jul 15, 2015 07:17 PM
