milled 706s
Old Dec 26, 2010 | 12:05 AM
matt29201's Avatar
Default milled 706s
just curious. what would the compression ratio be on a stock bottom end 5.3 if i had the stock 706 heads milled .050 and used a stock head gasket? i read the sticky but i suck at math. lol! any information would be greatly appreciated.
Old Dec 26, 2010 | 01:03 PM
matt29201's Avatar
is .050 to much?
Old Dec 26, 2010 | 01:21 PM
You should pm fastrt he milled a set of heads .050 and thinner head gaskets to get his compression up.
Old Dec 26, 2010 | 01:28 PM
Beatdown Z's Avatar
Laid Back
I'm guessing around 10.3-10.6:1
Old Dec 30, 2010 | 07:32 PM
YenkoST's Avatar
Basically, with a .050 mill, you are removing 7.14cc's. So, stock 706 casting is 61.15 - 7.14 cc = 54.01cc's. Thus moving your compression from 9.5:1 to roughly (with the same head gasket) to 10.2:1. You would have to use a compression calculator to confirm with the piston cc's, deck clearance, gasket thickness, etc.
Old Dec 30, 2010 | 09:51 PM
matt29201's Avatar
thanks for the help guys.
Old Dec 30, 2010 | 09:56 PM
1slowz71's Avatar
i milled my heads .050 youll be fine and as far as compression 10.6: sound good the only thing you will have to change will be the pushrods maybe 7.350
or smaller
Old Jan 1, 2011 | 11:31 PM
Slik2KRado's Avatar
i had my 706s milled .35 and used stock GM head gaskets and it does good. just needed 7.350 pushrods.
Old Jan 2, 2011 | 09:42 AM
matt29201's Avatar
thanks i was planning on some new pushrods.but i am curious how much camshaft i can run with out running into ptv clearance issues? i would like try a tsp224 or maybe one of the new lsr lobe cams. any insight would be appreciated
Old Jan 2, 2011 | 09:57 AM
Rhino79's Avatar
9 Second Club
I would think you would be ok with a mid to upper 220's cam without any clearance issues. I have done a 5.3 w stock heads milled .045 on stock gaskets run a 226/226 with no probs at all.
