Mild LQ4 built for towing
Old Sep 12, 2011 | 10:46 PM
jmj85's Avatar
Default Mild LQ4 built for towing
My 2001 240,000mile, 5.3/4L60/4x4 Tahoe Tow/winter rig is Tired. Last weekend I I pulled my 5500lb boat over the pass at a neck breaking 40mph. This rig gets driven maybe 4000 miles a year, So I’d rather not dump to ton of money into it. I’m not looking at 1/4m, or high rear wheel horsepower. Instead I’m looking for a reliable fun to driver tow rig that gets decent non-towing mpgs with a power band below 3600 rpms. Earlier this year I picked up a LQ4/4L80/TC all mated with 98K out of a rolled 04 2500HD. So I’ve been doing my research and came up with five options ranging for leaves everything stock to stocker to radix w/a cam.
Here’s what I’m thinking: LQ4, with 206/212 cam, 7.4 hardened pushrods, PAC 1218 Springs, Timing Chain, Pacesetter LT headers, Tune, ….
But the things I’m question there worth for this build is TBSS intake w/ 87mm TB, will I benefit from this mod or not just leave the stock intake inplace. Besides then I wont’ need to do a DBW to DBC swap. And then Bigger Injectors? Do I need then, IIRC the TBSS intake has 30# injector.
Anyways what do you think?
Old Sep 12, 2011 | 10:56 PM
GMCtrk's Avatar
For your purposes, leave everything stock, down to the exhaust. It will pull great. The headers will do nothing for you below 3000 rpms.
Old Sep 12, 2011 | 11:21 PM
6789olds's Avatar
x2 get a tune for the 6.0 and some deep gears and it will tow great .
Old Sep 13, 2011 | 12:42 AM
jmj85's Avatar
What about improving overall performance and mpgs. I read that the 6.0 in stock form are under-cammed, is this not correct?
Old Sep 13, 2011 | 01:13 AM
pewterliftedz's Avatar
lq4-206/212-factory exhaust
keep your autotrac T case with the new input.
also look into some 4.10 or 4.56 gears depending on tire size.
Old Sep 13, 2011 | 09:09 AM
banker099's Avatar
im doing kind of the same build right now, i have a crew cab with a 4.8 and i just picked up a stock 89k mile lq4
my build will be as follows,
take heads off and mill .030
ls6 springs
see how it does on mileage and towing, if i need more power ill throw a small cam in it, 212 or something, but im betting just milling the heads will provide all the power i need...
Old Sep 13, 2011 | 09:38 PM
pdxmatt's Avatar
Sounds like an application where Thorley's would be a good header choice.
Old Sep 14, 2011 | 02:05 PM
banker099's Avatar
i just ordered a cam for mine....212/218 .533/.533....:/ lol
Old Sep 14, 2011 | 02:16 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Read this thread, just food for thought. https://www.performancetrucks.net/fo...ds-lq4-488441/
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
FlowmasterMufflers
Aug 28, 2015 10:58 AM
Azim05
Aug 27, 2015 05:33 PM
FlowmasterMufflers
Jul 22, 2015 01:29 PM
