Mild cam LQ9 future plans (heads/intake)
I would strongly advise to look in the classifieds regularly because you can find Holley or Edelbrock intakes for close to the same price you would pay for the port job. In fact, I think there is a Holley Hi Ram intake for sale last I checked for ~$600. That is not much more than you would pay for the port job. Now granted you may need other parts to make the intake work with your injectors and tb and such but if your trying to get all the power you can I would go with an aftermarket intake instead of spending money to port a stock one. Just my two cents though......
I would not use any type of Hi ram on your setup, you don't have the CI or the RPM to make use of it and your low and mid will suffer more. Ill go against the grain on this, I would absolutely go with the 218 intake port over the 226. That cam should run good, the 110lsa should keep the power from being way too high, but I suspect something is holding it back a hair on top end. I would expect peak to be another 200rpm or so higher. What does the exhaust setup consist of?
dkutej
Mar 20, 2016 11:02 AM
camarojunkie85
13
Feb 27, 2016 06:41 AM
