In the Middle of Engine Swap...Need HELP!!!
Old Apr 18, 2017 | 12:53 AM
01FormulaTA's Avatar
Default In the Middle of Engine Swap...Need HELP!!!
So I just got my 6.0 swapped and and im hooking everything back up and the new Cam Position Sensor connector doesnt match the original...
Removed a 2013 LMG 5.3 w VVT/AFM...Swapped in a 2015 L96 6.0 and deleted the VVT...Added the LS2 timing Cover w Cam Sensor intalled Part 12633906
Old Apr 18, 2017 | 12:57 AM
The purple connector doesnt match the cnnector on the LS2 Cover?
Old Apr 18, 2017 | 02:16 AM
Three6GMC's Avatar
yep same thing I ran into.... can either re pin the cover harness with the factory cover connector or buy the adapter from BTR. Sensors are the same just that little jumper harness is different from the cars to the trucks with VVT as far as I know.
https://www.briantooleyracing.com/bp...r-harness.html
Old Apr 18, 2017 | 02:34 AM
Thanks for the reply! If I cut off the old connector from the original timing cover how hard is it to swap that connector for the LS2 style connector? Any soldering required? (just need to get my truck back up and running ASAP as its my Daily)
Old Apr 18, 2017 | 04:07 AM
Three6GMC's Avatar
Think the pins are the same just undo the pins from the new connector on the cover harness and repin into the factory cover harness. Shouldn't be any soldering that way but if you do end up having to cut wires its only 3 anyways. No biggie.
