Measuring for a 28" or 34" radiator?
Old Dec 18, 2014 | 10:49 AM
slonlow2000's Avatar
Default Measuring for a 28" or 34" radiator?
I've been searching, found a ton of info on the swap except the answer to how to tell which rad you have. I've seen some people say to measure only area between the end tanks, and then some say all the way to the end of the tanks. Which way is it?
Old Dec 18, 2014 | 11:10 AM
mdwatts11's Avatar
It's referencing the core
Old Dec 18, 2014 | 11:52 AM
Atomic's Avatar
I have a gauge for that
Just the metal core in the middle. It doesnt help the 28" radiator measures about 34" outside to outside, leading to most of the confusion.
Old Dec 18, 2014 | 01:16 PM
Well damn, that's where I was stuck. I didn't luck out and have the larger one. Thanks for the info guys
Old Dec 26, 2014 | 06:26 PM
cooter1989's Avatar
also an easy way to tell is the larger radiator usually has the e fans or the engine oil cooler and sometimes both
03sierraslt
14
Oct 9, 2015 05:53 AM
Tigger Welder
Oct 1, 2015 08:41 AM
old motorhead
Sep 29, 2015 08:22 PM
TrickTurbo
Sep 25, 2015 11:22 AM
