Maxing out injectors?
Old Oct 6, 2004 | 03:56 PM
marc_w's Avatar
You sound like my old electronics shop teacher, Ed... He used to tell us, "Everything electronic is made out of smoke... When you break something you'll let the smoke out..."
Old Oct 6, 2004 | 03:57 PM
onyx's Avatar
14 Second Truck Club
why not just tell the PCM to do 100% then? why the 125%?
Old Oct 7, 2004 | 10:29 AM
marc_w's Avatar
Edit that... I'm seeing a tick over 96%. Should I be worried?
Old Oct 7, 2004 | 02:08 PM
That seems more in line for your setup with the cam. Unless you are doing WOT runs every day, you should be ok for a while. I know some will disagree, but I think a few seconds of "static" injectors on an infrequent basis is not a huge problem - as long as you're not going lean and getting detonation problems.
Old Oct 7, 2004 | 02:18 PM
BigTex's Avatar
Thats the problem.... The PCM just knows it needs X amount of fuel. That "X amount" happens to be 125% of the capacity of the injector. The PCM just has to open the injector 100% of the time.
Old Oct 7, 2004 | 02:19 PM
BigTex's Avatar
I agree w/ deezel on your situation marc. More than likely that 96% is just that split second of peak rpms too.
Old Oct 7, 2004 | 02:21 PM
onyx's Avatar
oooooooooooooohhhhhhhh
gaps
Oct 15, 2015 02:53 PM
Pontiac Derek
Sep 19, 2015 01:49 PM
Justin87gn
Sep 10, 2015 12:06 PM
2004gibbstruck
Sep 7, 2015 06:05 PM
lxcoupe
Sep 2, 2015 12:58 AM
