Max lift on a '01 LS6 valve spring? (solid blue in color)
Old Jan 5, 2006 | 11:18 PM
hirdlej's Avatar
Default Max lift on a '01 LS6 valve spring? (solid blue in color)
I'm thinking of yanking the '01 Z06 cam out of my truck and putting something else in. What's the max valve lift I can go with these springs? I'm not swapping them again. I thought I saw somewhere I can go up to a .540 lift. Does this sound right? I am thinking of order the Vinci 044 for my app.
DUR @ .004" 272* / 280*
DUR @ .050" 210*/ 218*
LIFT .531/.531
OVERLAP 48*
LSA 114*
Old Jan 5, 2006 | 11:25 PM
99Silver6.0's Avatar
Think its .550 if I remember right.
Old Jan 6, 2006 | 01:40 AM
FarmerBeau's Avatar
Sexy Party Mod
Not saying 99silver is wrong but i have seen that GM rates them at .570. I guess they are very similar to Comp 915s?
Old Jan 6, 2006 | 06:58 AM
hirdlej's Avatar
Can anyone else confirm this? If that's the case I'm golden I should be able to do a cam swap in an afternoon and not 2 days. Those valve springs were a bitch to change out let me tell you! If you guys remember one of my previous threads I was disappointed about my dyno numbers and we even thought that maybe I was sold a LS1 cam rather than a LS6 cam. I can neither confirm or deny that fact yet, however I want to be ready to buy a new cam this spring and know what cams to start looking at since I already have the solid blue LS6 cam springs installed.
Thanks,
Joe
Old Jan 6, 2006 | 07:31 AM
FILE's Avatar
This is for the 02 and newer ls6 springs. I am not sure on the 01's but I do know it's less than .570.
Old Jan 6, 2006 | 07:43 AM
hirdlej's Avatar
I think I found my own answer....... Looks like the'01 spring is only good to up a .540 lift :/
http://www.h2fanatic.com/forum/archi...php/t-152.html
Old Jan 6, 2006 | 05:19 PM
5.3 racer's Avatar
i have run .540 with the solid blues, the springs did show signs of coil bind on 3/4's of the spring so they were definitely close to being maxed out.
Old Jan 6, 2006 | 07:46 PM
ktmrider's Avatar
Yes this is the very max. I had mine measured before installing with an 01 Z06 cam with 0.525" of lift. The combo seal/seat had me max at 0.545". The yellow 02' Z06 springs will go to 0.570" lift ( cam lift is 0.550" like posted ).
ARC
57
Feb 21, 2022 10:54 AM
Jake99
Aug 8, 2015 07:56 AM
LARRY01Z28
Aug 1, 2015 10:15 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
07NBSChevy
20
Jul 8, 2015 07:27 PM
