max bore on a 4.8
Old Jan 24, 2005 | 05:30 PM
Default max bore on a 4.8
Hey guys. I was wondering what the max bore on a 4.8 would be? Could you go .30 over very easy?
Old Jan 24, 2005 | 06:08 PM
XLR8NSS's Avatar
Adkoonerstrator
Since it's the same block and liner used as the 5.3L I would say .030" is no problem. Guys have taken the 5.3L block out .120" so they can use a aftermarket LS1 piston at 3.900". Going that far over you may have to have the cylinder walls checked for thickness but, I know several people have done it.
Old Jan 25, 2005 | 10:33 AM
ktmrider's Avatar
I am one who did the "overbore", check my signature for more.
For sure have the block sonic checked first before going my route, just to make sure there were no casting issues when new. Should cost about $75 or so, good insurance.
Also note the 4.8 and 5.3 share the exact same bore so either block will work for the massive overbore.
Be careful of the "standard" overbore diameters as few to no aftermarket companies make pistons/rings for the smaller truck engines. You can do custom but the extra cost would be better spent for the big overbore to run LS1 internals.
Good luck, it's doable and fun!
Old Jan 25, 2005 | 12:23 PM
Thanks alot for the info guys. This will be very helpful.
AdaMax
May 16, 2016 11:35 PM
legerwn
56
Nov 15, 2015 10:21 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
Wolftrk99
Oct 2, 2015 08:17 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
