Mast Motorsports vs Comp VVT?
Old Apr 18, 2009 | 03:12 PM
norris_83's Avatar
Default Mast Motorsports vs Comp VVT?
I'm looking to get a cam to plug and play with the VVT. Either of the cams will have to use the phaser kit..
Comp Cams 271-PHR-14:
Duration: 218-232
Lift: .563/.575
Lobe: 114
Supposed power is from 1800-6900...
Mast Motorsports Escalde Cam L92 is:
Duration: 220/234
Lift: .570/.588
Lobe: 116
Mast has told me this would pull hard all the way to 6500rpm...
I will be ordering the phaser kit from Comp, but since I don't tow anything at all, and I'm looking for something that will keep pulling hard throughout the rpm...
Any ideas on which would suit best?
On another note, anyone tried on ***www.byunspeed.com***.. They offer the Mast at a great price!
Old Apr 29, 2009 | 04:53 AM
norris_83's Avatar
Well I ordered the cam and its getting installed as we speak.. bought it from Byunspeed which i must say is a great company to deal with!
Will re-tune it tonight and hopefully get it run on the dyno sometime this week..
I should've added, it's the Mast Motorsports Escalade L92 cam. Cam swap is a pain in the ***, since no one has dealt with the VVT stuff here, i was their guenia pig... hopefully all will be good by tonight..
Old Apr 29, 2009 | 06:02 AM
Tootall's Avatar
how did you hold up the lifters ?
Old May 1, 2009 | 06:24 PM
CI DENALI's Avatar
Hey Norris. How did the cam swap go? Hopefully you've got it sorted and can tell us the dyno results.
Did the cam come with a new phaser? Also, did you change the valve springs? If so, what did you go with?
Old May 2, 2009 | 09:18 PM
norris_83's Avatar
i've had a few problems running into this cam... i thought mast would've been using the same a comps phaser kit, but they have a different kit that allows for more retard and advance without any ptv issues... will be ordering that and installing it soon...
springs i went with the 918s... mast also told me those springs seat pressure are a lot stronger then what was intended for the cam.. so i think ill be getting new springs as well...
once i order the correct parts ill post back with results... the only problems im running into are at idle, but cruise and wot it's a beast! mast told me i wasn't even releasing the full power of it, so hopefully once its corrected ill have double the happy face
thompson
Dec 27, 2017 06:48 AM
Velocity1
Oct 2, 2015 08:01 AM
jtphelps289
Sep 30, 2015 09:26 PM
Silver8ado
Sep 30, 2015 11:42 AM
sTNT971
Sep 26, 2015 04:22 PM
