Mass air meter and silicone conectors what do I use?
Old Apr 19, 2009 | 07:48 PM
Dark Halo's Avatar
Default Mass air meter and silicone conectors what do I use?
I have a new intake and I am now using a 90mm TB, I am wondering if I should steo up to a larger mass air meter? Will a 85mm slp or something of that sort work or should I look for something else? Also where can I get a large enough silicone conector for the 90mm TB? Also if anybody knows where I can buy a 4 1/2 peice os aluminum tubing so I can fab some type of cold air set up. If you would like to see what I have I got pictures here https://www.performancetrucks.net/fo...d.php?t=438952
Old Apr 19, 2009 | 07:57 PM
dirt track racer 81's Avatar
id do away with the maf. 4 inch will be plenty.
Old Apr 19, 2009 | 08:16 PM
budhayes3's Avatar
PT's Slowest Truck
I remember a thread where someone posted a link to a website that sells all sorts of silicone connectors and CAI parts and whatnot, can't remember who it was and the thread title though Maybe try google and you'll find some sites
Old Apr 19, 2009 | 08:29 PM
terravast4's Avatar
Jegs sells some intake tubes and connectors they have a 4" dia and 4" length aluminum for like 11.99 the part # is 865-9709 they have a whole section on 4" dia pieces.
Old Apr 19, 2009 | 08:34 PM
neilownz's Avatar
lingenfelter has a 100mm maf. 4 inches...
http://www.lingenfelter.com/mm5/merc...Category_Code=
search for spectre 4 on summit to find all sorts of 4 inch couplers and aluminum piping. pretty cheap compared to buying something premade i guess.
http://store.summitracing.com/egnsea...5&autoview=sku
Old Apr 19, 2009 | 08:41 PM
sonoma43's Avatar
dont mean to threadjack but when does the MAF get to its accurate reading limit?
Old Apr 19, 2009 | 10:13 PM
Dark Halo's Avatar
what is the advantage of doing away with the maf?
Old Apr 19, 2009 | 10:37 PM
neilownz's Avatar
You have to get a speed density tune. google that.
Old Apr 19, 2009 | 10:46 PM
Dark Halo's Avatar
I guess what I am asking is why is this the better option vs a maf? I dont think I dont think I am maxing the maf, I just was trying to upgrade to match the new throttle body. If a SD tune is better I would be intrested in giving it a try.
Old Apr 19, 2009 | 10:51 PM
alot of guys go to sd, do away with maf and o2 sensors. never have to worry about them going bad. why go spend 300 on a new maf when you can do a sd tune. i like the driveability of sd tune. I have it set to run lean at cruise and get better mileage. Throttle response seems better as well.. just my opinion, im sure someone can prove me wrong tho
