MAS or O2 sensor?
Old Apr 17, 2008 | 01:04 AM
ridered4life's Avatar
Default MAS or O2 sensor?
ok here is the deal. i walk out to my truck in the morning, start it up to let it warm up, and light up a cigarette to kill the few minutes its going to take. Well about 30 seconds after i start it, my truck starts to idle very sporadically going from 1000 rpm to 300 to 500 to 1200 to 200 and so on. so i shut it off in a hurry, let it sit for a second and start it back up. When i start it back up it runs normal and doesn't happen for the rest of the day. Now i have been having problems with my truck knocking for a while now and cant get it to go away. i have changed plugs, wire, fuel filter, air filter, sprayed MAS with MAS cleaner, and ran countless cans of sea foam through it. I was told the idle is the truck going from a closed to open loop or something like that and the weird idle means a sensor is failing. i also am a student and dont have money to throw at the problem. thanks so much for any input.
Old Apr 17, 2008 | 08:37 AM
02burban's Avatar
I Had A Simular Proble With Wy Suburban And I Beleive The Code Showed The Map Sensor... My Truck Will Idle Very Poorly When Starting Up Sometime Mostly When A Cold Startup, It Continue To Get Worse Untill I Change The Map Sensor And It Went A Way... I Put The Peddle To The Metal While In Idle And It Worked Sometime Untill It Was Fixed... I Have Heared You Can Clean The Map Sensor And It Mite Work... Have Auto Zone Check It And You Will Not Have To Guess At It... I Use My Diablo To Read The Code But Do Not Remember What Was The Code...
Hope It Will Help...
Old Apr 17, 2008 | 11:38 AM
booger78z28's Avatar
make sure the MAF is clean, first and try it again...
Old Apr 19, 2008 | 10:58 PM
i did and it didnt help. whats a MAF cost?
Old Apr 20, 2008 | 09:57 AM
OnyxSilveradoSS's Avatar
The Manifold Absoulte Pressure Sensor is kind of pricy, I think they are almost $60 new. I found one for $20 on egay.
Old Apr 20, 2008 | 12:04 PM
silveradokidd_4518's Avatar
a "new" MAF from O'riley's cost me about 80 i think. and ya the MAP is pretty pricey as well. i thinki paid 60 or so for mine
Old Apr 22, 2008 | 10:05 AM
A-Dub's Avatar
When you first start a cold truck, the computer does not reference the MAF or the O2s. I would start by pulling the throttle body and cleaning it out. Remove the IAC and clean it as well.
Need more info on the truck, what year, engine, mods etc
150NOS
Feb 27, 2015 09:28 AM
AlanHall
May 2, 2014 04:27 PM
camochevy21
19
Sep 18, 2009 08:59 PM
negativeswitches
Mar 7, 2006 01:16 AM
work in progress
Jun 28, 2002 06:59 PM
