MagnaFlow True Dual with X
Here is a few snap shots:
Under vehicle shot
Front Section
Tru-X
Dual Muffler
The design is not locked in stone and I will be firing her up and doing a sound byte shortly.
Richard
Under vehicle shot
Front Section
Tru-X
Dual Muffler
Richard
Originally Posted by Tiburon
Awesome set up. I have this same set up on my wife's truck only difference is I have an H pipe. Are there any proven gains going with an X pipe?
You can just as well go from dual exhaust into one muffler, then back out two or one tailpipe.
The gains will be about the same.
You actually get better throttle response and more low end torque on a single muffler set-up vs. a dual set-up. (Better in town fuel eco. and better towing power).
A complete dual set-up will give you more torque and HP in the upper RPM range. Not much, but a little more. (Good for drag racing or sound preference).
Jim
The x pipe helps equal out the pressure in the two exhaust pipes so regardless of how long the pipes are before the x it equals out the pressure so about the same amount of exhaust gas is flowing through each muffler so you dont have one pipe flowing twice as much as the other if only for intstant but it helps I have one on my truck. Main thing I noticed was it took alot of the popping and gurgling out of the exhaust but didnt really feel in the SOTP meter.
