MAF sensor
Old Dec 11, 2007 | 02:15 AM
wastedrubber's Avatar
Angry MAF sensor
What a piece of put it on (granatelli) then drove 2 hours to work, what a waste of money. has anyone had any real gains from one of these? I feel like the victim of a joke.
on a side note, i've got a granatelli MAF sensor for sale! any takers?
edit: wish i'd read the bolt on thread before now.
Last edited by wastedrubber; Dec 11, 2007 at 02:22 AM. Reason: my issue with being a trigger happy idiot
Old Dec 11, 2007 | 03:10 AM
howard quick's Avatar
Yeah...was going to say "should have done a search".
Piece of crap!
Old Dec 11, 2007 | 07:40 AM
sprayed8's Avatar
i got the JET MAF and i agree about the waste of money. when i had my truck dyno tuned about a week after i put it on my tuner had to spend literally 45 minutes and four pulls to correct the A/F ratio that the senor was messing up. one it was properly tuned i think it may have helped ever so slightly, but you shouldnt need to have a $400 dyno tune to go with it.
Old Dec 11, 2007 | 09:31 AM
thunder550's Avatar
High on diesel fumes
The only purpose of a MAF sensor is to measure how much air is going into the engine. Changing the MAF won't gain you anything....it's not small enough to be a restriction on your everyday engine. It doesn't help you get more or less air into the engine. All it does is measure airflow, which is based on your setup downstream from the MAF. IIRC, the embedded IAT sensor in the MAF fools the PCM into thinking the air is cooler than it really is, so the PCM may add a few more degrees of timing to compensate. For the ridiculous prices that these things sell for, you can get a tune that will do the same thing the RIGHT way and will get you even better gains.
Changing MAF sensor for more power makes about as much sense as changing an O2 sensor for more power.
Old Dec 11, 2007 | 11:50 AM
budhayes3's Avatar
PT's Slowest Truck
Lol, I like that one..."Hi Perf O2 Sensors now available from Granatelli"
Old Dec 11, 2007 | 05:29 PM
fortunately i got it for relatively cheap (165 compared to nearly 400 new) from a member on the site. I'll give him credit for finding a sucker anyway. now its a fancy paperweight.
Old Dec 11, 2007 | 05:34 PM
thunder550's Avatar
It'll work just fine if you recalibrate your MAF tables in your tune. You won't gain anything, but your truck will be back to its normal self again.
Old Dec 11, 2007 | 06:58 PM
05RST2NV's Avatar
I know several people that feel the same as you do...
Old Dec 11, 2007 | 07:01 PM
nonnieselman's Avatar
Dont feel bad man.. i still have a Hypercrapper as a paper weight....
Old Dec 11, 2007 | 10:29 PM
Putting the stocker back on first chance i get to pop the hood.
