maf failure
Old Jun 5, 2003 | 12:20 AM
bigguy75inches's Avatar
Default maf failure
After not being impressed with the power of my whipplecharger i finially bought a scanner.
It immedialty thru out a code and said, maf low input failure.
do you think this could be hindering my performance?
also it only registered 260 grams of air at full throttle max.
any info and ideas as to fix it are appreciated! Drew
Old Jun 5, 2003 | 12:46 AM
Ryan23silverado's Avatar
Default Re: maf failure
not 100% sure, I will have to check tomorrow, but I think my MAF read high 300s at WOT. Check and make sure all three of the heater/sensor wires inside of the MAF are looking in good condition.
Old Jun 5, 2003 | 07:50 AM
GREGGO's Avatar
Clean it with a NON-OIL contact cleaner. If that doesn't work, get a new one.
Old Jun 5, 2003 | 09:18 AM
can i use rubbing alchol?
Old Jun 5, 2003 | 12:13 PM
BigKID's Avatar
You can use rubbing alcohol and a q-tip but be VERY CAREFULL but I would recomend what Greg said (arisol non-oil contact cleaner) so you dont have an expensive slip of the hand.
BTW... If you do mess up or it turns out bad, I have a stock meter I will make you a deal on.
lucas287
31
Jan 12, 2021 06:18 AM
Aaron Arceneaux
Dec 21, 2015 02:54 PM
legerwn
56
Nov 15, 2015 10:21 PM
JordanH
Oct 3, 2015 03:59 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
