as&m headers
Old May 15, 2004 | 12:49 PM
  #21
Blake @ FMS's Avatar
FormerVendor
Originally Posted by BigTex
It should be an easy modification to add EGR to those headers. All they do is drill a little hole on the top of one of the primary tubes, weld on a small 1/2" diameter tube, then top the tube with an EGR flange. I'd think that most exhaust shops could do that for you. Since they aren't on the truck, it should be an easy task.
well thats deff something to consider. i was just going to wait and use ls1edit to delete EGR because i'll need edit when i do the lq9 or lq4 conversion.
When the EGR ports are welded on, does the weld bead rust since its not coated like the rest of the headers? I think i would rather wait until edit comes in if thats the case. its deff and option tho... ill look into it more thanks for the input
Velocity1
Oct 12, 2015 10:39 PM
Superman09
Sep 25, 2015 05:55 AM
dirt track racer 81
Sep 21, 2015 06:44 PM
5.3lSilverado
Sep 20, 2015 06:48 PM
