LT1 fans on the way, wiring help inside
Old Jun 6, 2006 | 03:17 PM
Z284thgen's Avatar
11 Second Club
Originally Posted by Nickvrebel
mine work great
and what are you complaining about Jeff, you had the same setup in your old truck forever, not like it's anything new
no i quick ghetto rigged this one up the truck had a very clean install i replicated the same thing on ross's truck last thur. when we installed his
Old Jun 6, 2006 | 09:36 PM
white1's Avatar
Your **** be on its way, shaddup
Old Jun 6, 2006 | 09:46 PM
Z284thgen's Avatar
11 Second Club
its mad ghetto rigged bro
got a switch just hanging
Old Jun 7, 2006 | 01:33 AM
just talked with white, hes gonna send me a harness with a switch wired up and the pin later when i need it. switch open both run half speed a/c on one full switch closed both and a/c on both full.
Old Jun 7, 2006 | 07:47 AM
white1's Avatar
Hold up, the switch is going to replace the PCM pin, thats it. When the switch is off, the fans will be off. When you flip the switch on, both fans will come on half speed (just like the PCM turned them on) if you have the switch off, when the A/C is on, one fan will run full speed. When the switch is on, and the A/C is on, both fans run full speed.
Old Jun 7, 2006 | 10:34 AM
GOTCHA!
im finally in the clear ha ha thanks matt.
Old Jun 7, 2006 | 11:55 AM
white1's Avatar
GOTCHA!
no problem
Porscharu914
14
Jan 20, 2016 10:45 AM
kalikid06
20
Oct 13, 2015 07:37 AM
97gmc
22
Sep 8, 2015 10:56 PM
muncie21
Sep 7, 2015 09:55 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
