LT1 fans installed!
Old Dec 26, 2002 | 05:37 PM
Default LT1 fans installed!
Total install took about 4 hours to do, I took my time. I removed the stock fan and shroud, and installed the fans yesterday. I made four brackets, two for the top and two for the bottom. I had to wait until today to get the wiring kit, it has fuses, relay, etc. Took another two hours today, I put all the wires in the black wire looms, looks good. I let the truck warm up and set the t-stat. I kept bumping the setting up until the fans weren't on when I was driving but they will come on it if I sit and idle for about five minutes. Just drove to the store and back, 35 mph all the way and the fans didn't come on. I let the truck sit in the garage and idle, it took about five minutes for the fans to kick on. So far I'm happy, I'll do some 0-60 runs when the roads dry out, it's raining right now.
Jim
Old Dec 26, 2002 | 06:46 PM
GREGGO's Avatar
Default Re: LT1 fans installed!
Sounds good. What temp setting did you wind up with? And does that kit allow for independent control or just one?
Greg
Old Dec 27, 2002 | 01:29 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Sounds good. What temp setting did you wind up with? And does that kit allow for independent control or just one?
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I'm not sure what the temp is, the t-stat on the relay is VERY small, no numbers. I'm going to use an infra-red temp gun we use at work to check the temp of A/C units, steam traps, etc. I'll shoot the radiator right where the temp probe is for the fans t-stat. The wiring kit I got doesn't allow for independent fan operation. I have them both coming on when the t-stat calls for them. They aren't as loud inside the truck as I thought they would be with the windows rolled up and the hood down. When I had the hood up and was testing them, they make some pretty good noise. They are a lot quieter than the clutch fan when it's engaged. I drove around tonight and in a 25 mile trip, they only came on two times. Once I was in stop and go traffic on the freeway, and the other when I was going from stop light to stop light. I tweeked them a little more so they wouldn't come on as quick. So far, all is good.
Jim
Old Dec 27, 2002 | 11:26 AM
CashDudeHomie's Avatar
Did you put some foam between the fans and the radiator? (Not sure if your fans even touch the radiator with your custom brackets) I ended up with a little dent in one of the cooling tubes on the radiator so I put some 2 inch foam along the top and a couple inches down each side and it keeps it cushioned.
Old Dec 27, 2002 | 02:34 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Did you put some foam between the fans and the radiator? </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yep, I used your advice on the foam. I had some weather stripping and put a strip of it on the top of the electric fan shroud. The sides don't touch and the bottom isn't a problem. The whole fan unit doesn't press against the radiator hardly at all and with the brackets, it won't go any where.
Jim
thunder550
Oct 8, 2015 04:53 PM
mr03silverado
Jul 17, 2015 02:15 PM
