LT-1 Fans
Old Apr 1, 2002 | 08:45 PM
RandyZ71's Avatar
Default LT-1 Fans
A buddy has a pair of complete LT-1 fans he wants to sell me for $75. I haven't seen them, but he says the are like new.
2 Questions:
1. Since I just installed the ud pulleys, are the fans worth installing?
2. How easy is this mod and what other parts will I need?
Thanks
Randy
Old Apr 1, 2002 | 09:14 PM
GREGGO's Avatar
Default Re: LT-1 Fans
1. Well worth installing. Doesn't create HP but frees some up, especialy on the low end.
2. Fairly easy install. You will need 2-30 amp relays 10' 12g wire for hot, 10' 12g wire for ground, 2- good quality toggles, 2-12g inline fuse holders w/30 amp fuses, 30' 16 or 18g wire for toggles. This is what is needed to run an in the cab on/off setup. I am eventually going to get a Flex-a-lite thermo switch to run one fan. I like being able to turn at least one on and off at will. Hopfully by the time you get ready to do it, I will have my step by step instructions together.
CD82
Oct 23, 2015 07:32 AM
Wrecker 426
Sep 30, 2015 09:39 PM
old motorhead
Sep 29, 2015 08:22 PM
97gmc
22
Sep 8, 2015 10:56 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
