LSXRT 05 LQ4 questions
I have a 2005 LQ4 that originaly came with a DBW throttle body.I have installed a LSXRT intake and an waiting on my FAST DBC throttle body.In looking at the original 05 setup it does not look like there is a PCV valve,valve cover has just a nipple on it.I was assuming with my new combo that the drivers side valve cover nipple(were PCV valve was on early LS1) to intake and then passengers side nipple to throttle body,will this work or am I going to have issues this way??
Question two,FAST billet rails as well and the 54028FRC cross over line is to short to clear the truck intake,doe FAST make something else longer ot do i need to fab my own?
I assume by this FAST does not make a line?Also you would not happen to have pictures of the self tapping throttle cable bracket screws included in the LSXRT intake would you? Mine were missing an I need to find something correct to replace them with.
SlicksNchicks
Aug 31, 2015 10:56 PM
