LSR cams...
Old Apr 27, 2009 | 09:29 PM
silveradokidd_4518's Avatar
Default LSR cams...
who's running them?
how do you like?
what dont you like about it?
been looking at them a bit and wanna start planning a new motor build soon but just dont know what cam to go with yet...
Old Apr 27, 2009 | 11:50 PM
TXsilverado's Avatar
i have one
i like alot
pretty harsh on the valvetrain. gotta run shorter pushrods. i recomend patrick G to spec out a cam. his cam picked up 20hp over my old 226/226 cam.
Old Apr 28, 2009 | 08:16 AM
BlackGMC's Avatar
Resident Retard
i think mine is a modified LSR lobes...
Old Apr 28, 2009 | 03:43 PM
i have one
i like alot
which one did you go with?
what size pushrods?
are you ever gonna find a cam that you are happy with Corey? haha
on a side note, Corey, I may need you to data log my truck for Justin in a couple weeks if you have the time. getting a different tranny and a TB stall
Old Jul 7, 2009 | 10:31 AM
HotRodV6's Avatar
SyTy Speed Shop
Im looking at one of the LSr cams designed for 4.8/5.3 engines, its 215/223@.050 on a 112 LSA with .604/.610 lift with factory rockers. It says it works best in heavy vehicles, and makes strong mid range torque. My truck has Pacesetter LT's/ORY, CAI, 05+ efans, custom blackbear tune, and i have an LS2 truck intake and 90mm TB im going to install at the same time. Im obviously going to get it retuned as well.
How well do you think this cam would work in my 5.3 with a TT3000 or 3200 converter?
Old Jul 7, 2009 | 02:31 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
probably pretty good id say at least a 3200 stall or even a 3600 IMO and a set of 4.10s
who grinds this cam comp ?
Old Jul 7, 2009 | 10:07 PM
03_SS_22's Avatar
ya its a pretty new line of cams
Old Jul 9, 2009 | 11:41 PM
jophuss36's Avatar
I'm also curious about these lobes, I know there not as agressive as the lsk lobes but shouldn't get the valve float.... At least I hope not
Old Jul 10, 2009 | 05:10 PM
since i had to sell my block i was building, im starting to look back into these cams for my 4.8 but im looking into the 219/227 .607/.614 112 LSA
think Corey was also looking at this as well...
Old Jul 11, 2009 | 02:51 PM
HotRodV6's Avatar
SyTy Speed Shop
Ive decided to go with the exact same cam for my 5.3L, and im thinking it will be a nice setup, some will say the lift is way more than the stock heads need, but i plan to swap them out down the road.
I also emailed Yank about the converter, and Dave replied back saying the PT3200 would be the best choice.
If you get this installed before me, id def like to know your thoughts.
