LS6 valve spring ?
Old Mar 9, 2008 | 06:25 PM
sharpshooter's Avatar
Default LS6 valve spring ?
How much lift can I run with these springs?I've heard many different #'s.
Old Mar 9, 2008 | 07:39 PM
OnyxSilveradoSS's Avatar
the ls6 stock cam is .551/.555
I would not go much higher than that.
Old Mar 9, 2008 | 07:43 PM
RandomHero's Avatar
There are plenty of guys running those springs with cams that have .580 or less. Hell there are even quite a few who are running cams with .600 lift and still running those springs.
To be safe I would say .570 or less.
Old Mar 9, 2008 | 08:15 PM
06sierra5.3's Avatar
i have brand new 918's for sale if you need them
Old Mar 9, 2008 | 08:30 PM
mcfarlnd's Avatar
Un-Registered User
im gonna be running a gt1 cam with ls6 springs.
Old Mar 9, 2008 | 11:07 PM
Working out a deal right now to pick up a Vinci Trucker cam 216 224 .551 .551 to run with my D1SC and TT3000 Yank.I see I should be fine with the LS6 springs.
Old Mar 10, 2008 | 12:06 AM
2 tone 02's Avatar
Whats the gm part# for the Ls6 springs?
EDIT: Is 12499224 the correct part number? Thanks
Old Mar 10, 2008 | 12:44 AM
jakebdb56's Avatar
The yellow LS6 springs are rated for a higher lift than the blue ones. IIRC, the blue LS6 springs are good to .550 and the yellows are to .580 per Lingenfelter Performance.
Old Mar 10, 2008 | 08:32 AM
hirdlej's Avatar
Also keep in mind that the yellow springs aren't as resistant to "lofting" as the 918's or stiffer. Meaning when you're running a camshaft with more aggressive to really aggressive ramps the yellow LS6 springs may be more prone to lofting or allowing the roller tipped lifter to leave the camshaft for a moment and come back down (like a dirtbike going off a jump). I have not studied the yellow springs enough to see what they're capable of but will hope to report back sometime this spring. Perhaps with a short enough installed height you could get enough pressure out of the spring to make it act "bigger" or stiffer.
Old Mar 10, 2008 | 12:37 PM
A 216 224 shouldn't cause lofting?
