LS6 Valley Cover Vent Tube with TBSS Intake
Old Jun 6, 2013 | 06:31 PM
SumtinCoo's Avatar
Default LS6 Valley Cover Vent Tube with TBSS Intake
where do you route the vent tube from the valley cover? i saw that the ls1's use the pcv valve but the tbss intake doesnt have one. So do i tee into one of the valve cover vents or what? I'm going to be putting one on soon and i need to know how to route this tube.
thanks
Old Jun 8, 2013 | 01:28 AM
SumtinCoo's Avatar
C'mon someone's gotta know the answer to this
Old Jun 8, 2013 | 02:19 PM
ForcedTQ's Avatar
Lightbulb
Black nipple on top of intake where the truck valve cover mounted PCV line goes to. You need to make sure you've got a PCV valve or Orofice (constant size PCV regulating passage) between the valley cover outlet and the nipple on the top of the TBSS intake. It would also be VERY wise to toss a catch can inline there too.
Old Jun 8, 2013 | 02:46 PM
SumtinCoo's Avatar
So do I need to go buy a PCV valve and put that inline of the vent tube? Would I block off the driver side rear valve cover port or tee into that line?
Old Jun 9, 2013 | 05:55 PM
ForcedTQ's Avatar
Lightbulb
Block it off, or run it up to the passenger side valve cover fresh air line and T it in with that as you'll be drawing crank case vapors only from the valley cover. I would put a catch can as well in line between the PCV valve and the nipple on the top of the TBSS intake. To make sure you don't draw oil mist from the fresh air side into the intake tube/throttle body, you can throw a catch can inline with that too.
The_W
Oct 28, 2015 09:00 PM
USMCvet0311
Sep 30, 2015 10:34 AM
Denali08
Aug 9, 2015 04:34 PM
04450r
Jul 24, 2015 01:58 AM
Ammadien
Jul 22, 2015 08:50 PM
