LS6 springs with this cam ?
Old Apr 27, 2011 | 02:52 PM
1dirtybird's Avatar
how many turns past 0 lash dose it take to make 18ft lbs? those are too long man.
An easy way to check it screw in the rocker bolt till it is touching the push rod and there isnt any up or down play. then take your torque wrench and see how many turns it takes should be between 1 and 2 thats it.
Old Apr 27, 2011 | 03:15 PM
zeake's Avatar
I will try that. The push rods are 7.4
You can hear it if you listen real close in the video at about 30 seconds.
Old Apr 27, 2011 | 03:26 PM
Mangled03gmc's Avatar
Baltimore Whore
If your not tuned for the 80lbers thats the fuel issue.. You are going to winde up wiping rings, bearings or cylinders out if you can smell fuel that abundant in the oil.. Only time you should have a fuel smell to oil is when it needs to be changed.. As far as tq issues. Ya def could be a issue there
Old Apr 27, 2011 | 03:31 PM
zeake's Avatar
Crap can not try it till tomorrow or maybe friday. Can not find my torque wrench either.
Old Apr 27, 2011 | 04:03 PM
zeake's Avatar
Well I found the trq wrench and at 18'lbs the rocker bolts don't turn at all it clicks with no turning. Also pushrods with effort can be twisted. I have no up or down movement and they feel pretty tight. paranoia? Should I do a leak down test? or compression test?
Old Apr 27, 2011 | 10:48 PM
dmelvin's Avatar
The picture of the trashed PRs... was that on the lifter or the rocker arm side of the rod?
Old Apr 27, 2011 | 10:52 PM
zeake's Avatar
Rocker arm side. Rocker arm looked great. I would have replaced the lifters if the lifter side looked like that.
Old Apr 28, 2011 | 10:24 AM
1dirtybird's Avatar
and my bad its 22ftlbs
everything else is 18lbs
You need to loosen them then re-torque to see lol
go in 90* movements, that way you can see just how close. the 1st full turn should be easy then you shouldnt go over another turn to make it click.
Old Apr 28, 2011 | 05:19 PM
chevyrace47's Avatar
I replaced these a few weeks ago. I keep hearing what sounds like valve train noise. Or collapsed lifter but It comes and goes. Drives me nuts.
did they all look like that?
Old Apr 28, 2011 | 05:22 PM
zeake's Avatar
No just the inner cylinders on each side. They all had wear. But the centers looked the worst.
