ls6 springs
Old Jan 31, 2007 | 09:01 PM
mcfarlnd's Avatar
Un-Registered User
Default ls6 springs
whats the max lift for ls6 springs?????
Old Jan 31, 2007 | 09:22 PM
nightrunner's Avatar
Mr. Obvious
ive heard .550 mentioned once
Old Feb 1, 2007 | 12:58 PM
mcfarlnd's Avatar
Un-Registered User
someone here has to know for sure.
Old Feb 1, 2007 | 01:09 PM
KY_BOB's Avatar
Lingenfelter sells them in a kit with their GT2-3 cam which is .570ish lift.
Old Feb 1, 2007 | 01:12 PM
dirt track racer 81's Avatar
supposed to be .570 lift
Old Feb 1, 2007 | 04:31 PM
mcfarlnd's Avatar
Un-Registered User
thanks for the help
Old Feb 1, 2007 | 04:32 PM
mcfarlnd's Avatar
Un-Registered User
i think im just going to go with the 918s
Old Feb 2, 2007 | 08:41 AM
budhayes3's Avatar
PT's Slowest Truck
The ramp speed of the lobes has to be factored in when chosing LS6 springs also. As mentioned, Lingenfelter uses them with cams close to .580 lift, but I believe those cams have "lazy" lobes. On cams with agressive ramps (like Comp XER lobes and Thunder Racing Cams), you want that extra seat pressure to keep the lifters from jumping off the lobe as it spins...so I have read both here and at LS1Tech.
Old Feb 2, 2007 | 12:18 PM
mcfarlnd's Avatar
Un-Registered User
so, 918s will be good?????
Old Feb 2, 2007 | 12:27 PM
KY_BOB's Avatar
What cam are you going with?
