LS6 rockers on 5.3 do I need anything else
Old Aug 24, 2004 | 04:59 PM
Default LS6 rockers on 5.3 do I need anything else
Im just wondering if I put the LS6 rockers on my truck do I need anything else? Would putting the LS6 pushrods on change anything or am I ok with the stock ones? Thanks
Old Aug 26, 2004 | 01:40 PM
are ther any gains over stock rockers...I was looking at the specs and they are 1.7 on the 5.3 and 1.7 on the ls6
Old Aug 26, 2004 | 01:47 PM
gcooper's Avatar
There wouldnt be any gains. Unless the ls6 rockers weigh less and even then it is negligible. If you are paying for the rockers it is definately not worth the money. Only with a higher ratio rocker will you see gains because it increases the lift.
Old Aug 26, 2004 | 10:16 PM
ssierra's Avatar
want more lift check w/ SLP or COMP cams slp has 1.85:1 rockers w/ ls6 springs, locks and retainers for about 750$ and i think comp has 1.75 or 1.8:1 and better springs. locks and retainers, and they make a shaft mounted set of rockers too, oh and patriot performance has shaft rockers too.
5.3Okasai
Mar 9, 2022 01:07 PM
The_W
Oct 28, 2015 09:00 PM
darnie
Aug 10, 2015 10:25 AM
BigEd_72455
Aug 8, 2015 07:37 PM
Jake99
Aug 8, 2015 07:56 AM
