LS6 intake verses LS2 Truck intake
Old Jan 19, 2007 | 06:38 PM
14 Second Truck Club
Default LS6 intake verses LS2 Truck intake
What is the difference in these as far as flow, plenum volume and all that? Trying to figure out which one would be best for my 383. Thanks.
Old Jan 20, 2007 | 07:26 AM
Ttt...
Old Jan 20, 2007 | 07:33 AM
nightrunner's Avatar
Mr. Obvious
ya might talk to thunder550 he has the ssr ls2 truck intake
Old Jan 20, 2007 | 10:07 AM
thunder550's Avatar
High on diesel fumes
Yes he does, but he has no idea what the flow numbers are
Old Jan 20, 2007 | 10:19 AM
CHEVRACER83's Avatar
if you havent bought one yet.... look into the l92 intake... it is a pretty damn good flowing intake... and the runners are designed to make a good amount of HP in the upper end, while still making crushing Tq that your 383 is gonna wanna make
Old Jan 20, 2007 | 10:50 AM
ZR1 DREAMING's Avatar
There were several comparos over on tech. Despite having a 90mm tb the LS2 intake did not make as much power as the LS6 intake. The numbers were similar but not greater than the LS6.
Go the FAST 90, Vic Jr, or L92 for greatest power. And stick with the LS6 for the budget power.
Old Jan 20, 2007 | 10:53 AM
I agree with Z06.... you know i do bro.... but the port velocity at low speed is better... yes the peak numbers are great with the ls6.... but the overall... "where you drive" numbers are very good for the L92. and its not crazy expensive either
Old Jan 20, 2007 | 11:08 AM
Good point, I neglected to mention I'm running a 4k TC, and had a 3k TC for the LS6 intake.
Old Jan 20, 2007 | 11:28 AM
HAHA... yeah thats an important nte... and lets not mention what cam you were probably running....
I know 383s are known for neck snapping torque... I guess we should get more info about what he will be doing with the motor first....
so yeah.... what cam are you planning or already done, and what stall?
Old Jan 20, 2007 | 04:07 PM
Mr. Obvious
does the l92 intake work with non-l92 heads(what he has)?
