ls6 intake swap = zip, zilch, zero
Old Jun 2, 2008 | 01:13 PM
ZR1 DREAMING's Avatar
Originally Posted by RandomHero
The flow ratings aren't THAT much better over the truck intake. I'm sure you've seen them posted on here before the the ls6 intake wasn't very impressive.
It's not "flow ratings" that guys are switching to the LS6 as much as it is plenum volume. That's the big difference between the 2.
Old Jun 2, 2008 | 01:22 PM
Damn Stew, hopefully your next few times out will show a bit more improvement.
Old Jun 2, 2008 | 02:16 PM
budhayes3's Avatar
PT's Slowest Truck
From what I've read here through the years, the LS6 seems to be better above 6k...
Old Jun 2, 2008 | 02:26 PM
TXsilverado's Avatar
well i ran the truck intake up to 6900 rpm and the ls6 up to 6900 and didnt see any difference.
but the truck falls off at 5500 right
Old Jun 2, 2008 | 02:28 PM
Wheatley's Avatar
Truck Sponsor
May only be good to 5500 to some per say,but it sure wound to 6900 fine on yours
Old Jun 2, 2008 | 02:31 PM
regency's Avatar
man i need to get mine on a dyno and see where i need to be shifting!!!! im only at 6375...lol
Old Jun 2, 2008 | 05:55 PM
dlt76028's Avatar
same 60'?
Old Jun 2, 2008 | 06:18 PM
yep same 60
Old Jun 2, 2008 | 08:03 PM
TouchOfEvil04's Avatar
I think if you retuned it for injectors only then your just letting the setup failper your choice.
Let him retune it for the intake not the injectors and you might see a differance.
You don't swap cams and only change fuel......just my .02
Old Jun 2, 2008 | 08:05 PM
dlt76028's Avatar
i think you need more track, try the 1/4...
