ls6 intake onnewer trucks
Old Jun 10, 2007 | 08:13 PM
dry_kill's Avatar
Default ls6 intake onnewer trucks
i was just wondering if i would run into any problems putting this intake on a newer vehicle with the DBW TB since most of the ones i have seen swapped have been cable driven TB. ima be putting it on a 04 ls1 engine that i bought, want to get it all on while the motor is out, thx fellas
Old Jun 10, 2007 | 08:15 PM
Phantom's Avatar
11 Second Club
just have to grind a little on the tb...thats of course after you get a different water pump or modify the truck one...blue cajun just did it a few months ago
Old Jun 10, 2007 | 10:33 PM
bluecajun5.3's Avatar
11 Second Truck Club
Old Jun 10, 2007 | 10:44 PM
.T.'s Avatar
.T.
Joshluther has become a pro at the swap; modifying waterpumps.
Assuming you're using truck accessories on it.
Old Jun 11, 2007 | 09:57 AM
Tootall's Avatar
someone on here capped off the top hose, and then welded up another pipe pointing forward. . . there's pics but I can't remember who it was, he used the truck accessories.
Old Jun 13, 2007 | 09:03 AM
dry_kill's Avatar
well i have a ls1 engine and the water pump snout already faces outward, wonder if i could find someone on here to do the swap for me, i dont feel like dealing with it, i would rather pay for it
Old Jun 13, 2007 | 02:07 PM
dry_kill's Avatar
also i will need different injectors, is that correct?
Old Jun 13, 2007 | 02:28 PM
Tootall's Avatar
what accessories are you using . . . all the truck ones or the F-body accessories?
Old Jun 14, 2007 | 09:02 AM
dry_kill's Avatar
the trucks, except i may use the ls1 water pump and a ls6 intake
Old Jun 14, 2007 | 09:16 AM
Tootall's Avatar
the ls1 water pump will not work with the truck accessories, it'll bolt up just fine, but the belts will not line up
