LS6 Intake on 5.3 Heads?
Is this a possiblity? I know the LS6 heads bolt up to the 5.3 block so I would assume this to be true but need the truth man... I can handle it. Looking for some direct bolt on's with out swaping heads...yet!
But it will bolt right minus the correct fuel system setup right? I was thinking of either a Holley Lingenfelter which is desiged to be close to the same as the LS6 or the new Weiand(sp?)which lingenfelter helped design too. I am wanting to go SC some time in the future and want the extra strength of the aluminum. On LS1 fbodies it's a 20+ rwhp mod at the z28 mb. Would also better suporrt some NOS too!
From what I have read, it is not worth it. The LS6 intake only flows a little better than the truck intakes. The truck intakes are taller, that's why they won't fit on F-Body cars. Plus, you might loose some torque down low with that swap.
kent
kent
