LS6 heads onto 5.3L
Old Aug 20, 2003 | 07:12 PM
qwank's Avatar
Default LS6 heads onto 5.3L
as i posted in another post i got a free LS6, debating on if its worth the effort to put it in my truck or just use the heads. how much extra horsepower will just bolting on the heads onto the stock motor get me? also what is a good cam to use with the heads? will the LS6 cam work? this is probably the route i will go until i get the money to get the whole motor in. thanks.
Old Aug 20, 2003 | 07:22 PM
Smoky02's Avatar
Default Re: LS6 heads onto 5.3L
If I am correct from what I've learned at this post, ls6 heads will work and they flow alot better than your stock heads...
Old Aug 21, 2003 | 12:23 PM
Flem's Avatar
I've got LS-6 heads on my 5.3L Radicx supercharged suburban no problems works well. but in non s/c applications you'll lose about 3/10's of a point compression. 9.5:1 to 9.2:1.
Old Aug 21, 2003 | 12:31 PM
Banned
dude, if you have an entire LS6 motor setting there then but it in your truck. it would be more than worth it to have the extra cubic inches. you'd gain close to 70 rwhp probably over a 5.3 with a stock LS6, and since it's not in the truck yet throw a cam in it for good measure for another 20-30HP
Old Aug 24, 2003 | 04:07 PM
M.Roberts's Avatar
What he said.
Old Aug 24, 2003 | 05:44 PM
Hell yeah if you got a 6.0 sitting there, why would you even think of not using that motor!
5.3lSilverado
25
Aug 29, 2016 12:48 AM
The_W
Oct 28, 2015 09:00 PM
darnie
Aug 10, 2015 10:25 AM
LARRY01Z28
Aug 1, 2015 10:15 PM
Aboss
Jul 9, 2015 10:28 AM
