Ls6 Cam/install?
Old Dec 15, 2005 | 01:04 PM
getchusum99's Avatar
Default Ls6 Cam/install?
I Have An Ls6 Cam And Springs And Im Planning On Istallin It Within A Month, So Do I Need Longer Pushrods Due T Oa Smaller Base Circle? And Also Will Tuning For This Cam Wake It Up More Or Can I Leave Tuning Stock? Also Is This A Good Torque Cam For A Daily Reliable Driver? Plus I Got It Free!!and What Do I Need For The Install, Will My Lifters Fall? I Have Just Hit 200k On My Motor The Other Day.
Old Dec 15, 2005 | 07:22 PM
no one? come on!
Old Dec 16, 2005 | 12:25 AM
PappyDan's Avatar
Tribe Shaman
7.4 pushrods from comp or the early ls6 pushrods.
now there are two types of LS6 pushrods,
type one is the older LS6 where the push rod is longer.
type two is a stock length push rod because the valve stems on the newer LS6 is longer to make up the slack and so the factory could use the stock length on everything to save a few bucks.
the 7.4 from comp is a thicker rod and a lot stronger.
Old Dec 16, 2005 | 01:12 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
what year model is the cam too?
Old Dec 16, 2005 | 02:58 PM
Its An 03 Cam And Springs.. Do You Know How Much These Pushrods Cost?
Old Dec 16, 2005 | 04:06 PM
zippy's Avatar
you're deffinitly going to want to reprogram it. you'll probably be leaving 30 or so hp unused if you keep the stock tune. in a 5.3L the LS6 cam is going to peak hp at around 5800 or so and a 99' 5.3L has a stock rev limiter at around 5600 if i recall correctly. not only is the rev limiter going to be way too low, the shift points will be way off and with the rev limiter that low even manually shifting won't get you where you need to be. this doesn't even count for the V.E. table and spark timing that is going to be considerably off for your application using the stock tables.
Old Dec 16, 2005 | 04:29 PM
Thanks For The Info, I Hear The 02 Up Ls6 Cams Are Better?
Old Dec 16, 2005 | 05:49 PM
TURBO8's Avatar
Yeah! I just had mine changed today, (push rods) I had the stock push rods from the 5.3 in the motor and they where way too long. I had synergy measure and put in the 7.3's in. The motor was making good power but didn't sound right. I should get some better dyno #'s now. Yes change your push rods!
Old Dec 16, 2005 | 11:54 PM
TURBO8's Avatar
Yeah! with the mods in my sig. I used a 7.350 push rod.
Old Dec 17, 2005 | 12:05 PM
so should i go with a 7.4 pushrod or a 7.3?
